Thanks for the quick replyQxxx4 wrote:did you try the new deck? are u gettng any sound or anything? id say try that first and see what happens
You do not have to bypass the factory amps but it's highly recommended. The system will sound sub par. Not the cheapest way to go but I highly recommend a full speaker/amp overhaul.timmack wrote:i wanna say thats for the steering wheel controls? not sure. aint seen slickroger for a while, he could probably help out with that one. i think you also have to bypass the factory amps too, not sure if anyone here has tried to hook an aftermarket radio up to the amps or not.
is "bypass the factory amps " different menthod than "full speaker/amp overhaul"? What exactly is bypass the factory amps? Get to the amp on the door panel and reconnect the wire so that the wire goes directly to the speaker, but not the amp???Empty V wrote:
Billy
You are correct. If you were going to just bypass the factory amps I would just run new wire from the head unit directly to the speakers. From what I remember they has a weird connector on them so some splicing might be involved.racingqx4 wrote:
thanks!
oh man... I thought this whole thing would be simple and easy. I don't think I have time to do all the workEmpty V wrote:
Billy
Hate to break it to you but bose are some of the sh!tiest speakers on the market. I used to have stock JBL's in my old explorer limited that blew the bose stockers away. The only thing bose made right was their QC Headphones, I've never heard a single bose speaker that I liked, and I do A/V for a living.Qxxx4 wrote:....probably not the best out there but it is bose...so it alone is better than most vehicles out there.
As slickroger mentioned wires #1&2 can be left alone. Some decks ground through the wiring harness hence 6 and 3. Since the metal bracket is a good ground and is closer to the source or you could just leave #3 and connect 6 to the metal bracket. Going from memory I think I also had a power antenna which I left disconnected.racingqx4 wrote:ok I've connected the wires.... now here's what's left:
#1) a orange w/white stripe wire from my new cd player's adaptor, from the manual it say this is for "illumination", anyone know what it is? I don't see anything like this on the Nissan typical color thing on the InstallDr manual?
#2) this is an orange wire from the "H" position of the harness, according to InstallDr this position is "DO NOT USE", but somehow this adaptor has this orange wire, anyone know what it is?
#3, #4, #6) all black wires, I guess I can simply connect them to the metal bracket?
#5) black with white stripe, InstallDr said connect this wire to the radio ground wire... I guess I can connect it to the metal bracket as well?
Thanks!
Roger, they may sound good if you haven't heard any different. If you replaced those with something decent it'll be like a completely different, and much better system. You might also think a ride sounds good without dynamat or some other sound damping material if you haven't heard it with it.slickroger wrote:I disagree with the bad talk on the bose systems, im still using my bose speakers in my truck and they sound good. i dont have them playing any bass, i let my 2 12's do all of that.
It's really easy just make sure you have a panel popper otherwise you might break the clips or the cheapy cardboard they attach to on the door panel. It's just a couple of screws and then pop, pop, pop you're done(that sounds jacked up).Qxxx4 wrote:i might need your help come spring on how exactly you remove the door panels...i want to put foam insulation to reduce vibration a little
wow those are nice!!!
