My 2001 Pathfinder has gradually "acquired" this little problem... While driving, it runs great. I'll try to describe what happens when I pull up to a stop light:-engine idles down to 750 rpm exactly as expected.-after 25 seconds exactly (I've timed it), the idle speed drops down to 500 rpm or lower.-sometimes, the engine stalls out at this point-if the engine does not stall, it takes a couple seconds and then comes back up to 750 rpm
One interesting thing that I kind of stumbled upon by accident relates to this thread:
zer...valveThe thing I was asking about is the Swirl Control Valve (SCV) tank. It's basically a one-way valve with a vacuum accumulator tank on it. If I disconnect the hose from that tank and run the engine, this idle stall problem I described does not happen. Although it threw me a P1130 (Swirl Control Valve Solenoid problem) code as expected.
I've tried the Idle Air Volume Learning procedure as described in the FSM but the problem remains the exact same.
If anyone has any thoughts, I'd appreciate the input.
Modified by theppler at 8:21 AM 9/25/2008
Modified by theppler at 8:22 AM 9/25/2008
