2001 PATHFINDER SE MANUAL HEATER & AC CONTROL SWITCHES
LONGC98
Car: 2001 PATHFINDER SE
I HAVE A 2001 PATHFINDER SE WITH A 3-SWITCH MANUAL HEATER AND A/C CONTROL SYSTEM.
TODAY I HAD THE FAN SPEED SWITCH AND CONTROLLER REPLACED DUE TO THE FAN SWITCH GOING DEAD. SYSTEM WORKS PROPERLY NOW AFTER THE REPAIR.
IF YOU HAVE A 2001 SE WITH THE MANUAL 3-SWITCH SYSTEM, PLEASE ANSWER THIS QUESTION.
DO THE 3-SWITCHES ACROSS THE TOP OF THE PANEL ILLUMINATE OR LIGHT UP AT NIGHT?
I DO NOT MEAN THE A/C CONTROL BUTTON OR THE RECIRCULATION BUTTON TOWARDS THE BOTTOM OF THE PANEL. THOSE BUTTONS LIGHT UP WHEN BUTTON IS ACTIVATED.
I AM REFERRING TO THE 3 MANUAL SWITCHES AT THE TOP OF THE CONTROL PANEL THAT OPERATE FAN SPEED, COLD/HOT TEMP CONTROL, AND AIR FLOW CONTROL. DO THESE THREE SWITCHES LIGHT UP IN SOME MANNER AT NIGHT?
PLEASE CHECK YOUR VEHICLE AT NIGHT AND ADVISE.
THANK YOU
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
They should light up with the rest of the interior. If they do not, the two #74 bulbs are most likely dead.
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
Uh, could you turn off the caps button please. It implies that you are yelling. Gives me a headache. Thanks.
LONGC98
Thanks Towncivilian for the help, will return to the shop for a follow up on Monday to get it resolved. The link and FAQ is helpful too, a lot of good info there.
