Chris.m »
https://forums.nicoclub.com/chris-m-u165243.html
Sun Apr 07, 2013 10:27 pm
Just a heads-up,
You may be able to just put a toggle switch in between the wire and the ground to make a bypass that way.
If you hook it up to the parking brake, you may have to put it up and down three times to get it to work each time, which is a pain.
If you do the bypass, you can get it to work while driving.
This may not be the case, but finding the parking brake wire is hard, so a bypass would be killing two birds with one stone.
