warlam »
https://forums.nicoclub.com/warlam-u205133.html
Fri Jul 13, 2012 3:53 pm
Does anyone know the correct part number for a 2001(2000.5) Pathfinder 4wd Manual transmission transfer case? Apparently mine s*** itself after 60K miles with no lube(thank you used car dealer and my dumbass for never checking it) and I need to find a used replacement. Truck locked up on me at 65mph for a second and then drove normally for a mile at 35mph then locked up intermittently until I made it to the next exit at 10mph. After I parked it the rear end was locked up and had to be dragged onto a flatbed I didnt notice if the front wheels were locked up as well at that time b/c I was irate. It was in 2wd while all of this happened. A mechanic has undone the drive shaft and checked the rear end which is fine the transmission had good color lube and is full but the transfer case didn't even drain a thimble full so I am assuming that is what was causing it? If anyone thinks it may be something else or has a way to test it let me know as I dont want to buy the wrong part and blow anymore $$ than necessary. Also if anyone has a transfer case for sale send me a PM with mileage/price.
Thanks
