Mark Sheriff wrote:i also have to do this job, what symptoms are you having with the bad fuel pressure regulator? and i would also like to know the best way to go about replacing this
I replaced the FPR on my 2001 recently, and listed the symptoms to look for and what I was seeing. Check out the post here:
success-story-replaced-fuel-pressure-re ... 89289.html. It won't be much help on how to actually replace it, since it sounds like it's in a much different spot than mine. I'm still having trouble starting, though. I think it has something to do with the injectors at this point.
I found out the fuel damper was also in need of replacing, so consider doing that too. Dunno what the symptoms are; I was trying to fix another problem but it really smoothed out the idle and acceleration.
