loystock »
https://forums.nicoclub.com/loystock-u10145.html
Mon Jan 04, 2010 11:47 pm
The shop which replaced the coils did not do a proper diagnostic before and after the coil replacement. And to release the car to you, recommending a transmission flush because of 'sluggish' response is just beyond me. Return the car to their shop and demand a warranty repair. Most shops have at least 30 days warranty.
DTC P01320 indicates Ignition Signal in the PRIMARY CIRCUIT is not sent to the ECM during engine starting/running. Probable cause:-harness or connector between ECM and each ignition coil-condenser-Crankshaft Position Sensor (REF) or circuit.
Since the ignition coils (and plugs) are new and tested OK, those can be eliminated. So we concentrate on the Harness-Connector, Condenser and Crankshaft Position Sensor.
You car is equipped with DIS (Distributorless Ignition System). The Ignition Coil (6 ea.) has a built-in power transistor whose bias (control signal) is provided by the ECM. The coil is powered thru the ECM Relay anytime the Ignition Switch is ON. The Ignition Coil connector has 3 terminals as follows:-Pin 1 (striped wire) - is where the bias signal from the ECM l (@ 0.2VDC with engine at Idle) is connected to alternately turn ON/OFF the power transistor which then enables the spark plug(s) to fire or not. An oscilloscope will provide a better display of coil control signal-Pin 2 (B-Black wire) - is the GROUND connection for the coil. Make sure the engine harness ground points (top of engine, besides intake plenum) are clean and secure. Verify this with ohmmeter (@ 0 ohm if good).-Pin 3 (R-Red wire) - Battery voltage (11-14.7VDC) is connected to this pin and the CONDENSER (top of engine, besides harness) whenever the Ignition Switch is ON. If the voltage is low, the condenser may be leaking or shorted. The condenser acts like a 'shock absorber' for the ignition coil (too complicated to explain at this time). When disconnected, the condenser should read @ 1M-ohm at room temp.
The Crankshaft Position Sensor uses Hall-Effect to monitor the TDC (Top Dead Center) position so the ECM can send the appropriate ignition signal. This sensor is mounted near the crankshaft pulley with a typical resistance of 470-570 ohms.
If you have a multimeter, you can do the testing yourself so you can prove to the shop their botched diagnostic. The Bank 1 coils for cylinders 1-3-5 are on top of the engine, towards the firewall. The Bank 2 coils for cylinders 2-4-6 are towards the radiator and are accessible by removing the engine cover plate.
With Ignition ON (engine not running), check Pin 3 (red wire) of each ignition coil for presence of battery voltage (@ 12.5VDC) w.r.t. chassis GROUND. Each coil MUST have the battery voltage or it indicates problem with the harness/ECM connection. Absence of battery voltage indicates a bad ECM relay or wiring. Low voltage indicates a leaky condenser.
If the required voltage is present in each coil, then start the car and check the CONTROL signal from the ECM. Each Pin 3 (striped wire) should read an average of @ 0.2VDC w.r.t. chassis GROUND. If not, bad wiring or signal from ECM. The presence or this voltage indicates the crankshaft position sensor is working. Again, an oscilloscope, if available, will give a better display of 'firing' signal from the ECM.
Good Luck!
