Jiggy686 »
https://forums.nicoclub.com/jiggy686-u60000.html
Sat Sep 27, 2008 1:48 pm
I got a 2000 i30 with about 117k , my fuel economy sucks(15mpg NYC, 21-23mpg highway) cause my car is throwing a 1420 code which means the catalytic is no good, before the 1420 i was getting almost 20 in the city and just under 30 on the highway),
I only use premium 93octane and my i30 loves me 4 it, in terms of reliability i think the i30 is comparable to a Lexus even though I have problems with mine due to a car accident and negligence. Maintenance is very important with these cars. So far I have changed out 3 ignition coils , the MAF sensor, starter, alternator, a/c clutch , 2 cv axles and 2 calipers. Many of these repairs may have been necessary due to an accident i had around 98k where the front was damaged pretty bad.
So far the motor is running real strong and the tranny shifts perfectly 98% of the time. I recomend SYNTHETIC fluids cause they have made my car much smoother and are known to prolong life.
At 112k you should make sure the CV axles have not exploded and the rear calipers havent started to lock up . Also by then the MAF should have been replaced and the ignition coils too since both of these are very comon problems on the 2000. Also check the struts and exaust system.GOOD LUCK
