Maxima Girl »
https://forums.nicoclub.com/maxima-girl-u27414.html
Mon Feb 26, 2007 3:23 pm
I've always had 20's on both my 98 & 01.
I had to roll the fenders on both and re-paint them.
I changed my suspension and springs as well. If you have OEM suspension and 20's you'll look like your going 4 wheelin'.
MY 2001 used to rub a lot until I found the trick. Here is my secret:
I put Vogtland springs on the FRONT only with FULL tokico illuminas all around on setting 5.
I left the stock rear springs, which made the gap between the front and rear, IDENTICAL.
If you notice most ALL maximas are lower in the rear and a bit higher in the front. By lowering the front with Vogtlands and doing full suspension with 20's, my maxima sits completely flush and I have zero rub with my backseat packed with people.
Just my 2 cents.
