xairsoft808x wrote:The truck hesitates during lower rpm's as well now (~2k)
Thanks towncivilian. Just replaced the fuel filter. The previous owners records show that it was last done in 2006, so it was a bit overdue.
Problem still exists after the test drive. Any other suggestions?
Clean out your throttle body, there could be large carbon deposits in there. When I first got mine whenever I'd put my foot on the pedal it would get stuck, then with a hard press it would rev up high and then run fine afterwards. A huge cloud of black smoke came from my throttle body after cleaning it out, and that problem was gone. I had better acceleration and no hesitation.
You can also try cleaning out your mass air flow sensor. It may not solve your hesitation, but it the mass air flow sensor is dirty it will hurt your performance.
