I emailed you a photoJibberD wrote:A little thread drift here, while the info. on the plug type is appreciated; the question remains: Where are they located?
Don't be afraid to ask questions. This is a forum, we are all here to help!RussA89 wrote:Great question...As a new J owner, I'm looking for the same info, but didn't want to ask!
Thanks, I've read almost everything on this forum, and it's one of the best I've seen. You guys are very helpful and knowledgeable.driverdriver wrote:
Check out the the J30 Faq thread at the top of this forum. Lots of good info up there for newbie owners.
thats a very good idea, they can easily seize in the aluminum heads.fourdrinie wrote:you might want to add some spark plug grease (available in little packets at most auto parts stores) to the threads and the electrode tip...There are two kinds...one for the threads, which prevents corrosion and rust to set in on the threads, so the next time you replace them theyre easier to get out. The other is di-electric grease for the electrode parts which help the electrical connection in the spark plug boot, as well as help resist corrosion.
OH i thought it was a iron block, aluminum heads.. maybe im wrong. Either way, its a good idea to do that anywayDominickJ30 wrote:Im pretty sure the VG is an all cast iron motor. I could be wrong tho.
