wmc wrote:Steve, thanks for the help. I am going to start cleaning soon. I bought some of the parts and got a repair manual so lets see where that leads to.
One question though, the part that says MIL does not illuminate when the key is turned and the engine is off.. how do I fix that?
Here is the book I am using page EC-209
http://www.nicoclub.com/FSM/i30/1997_I30/ec.pdf
You will need to remove the tube that contains the EGR temperature sensor is the one that will need to be cleaned.
BGs throttle cleaner would be a waste here. I have tried that and the amount required would be surprisingly expensive.
To replace the MIL you will have to remove the gauge cluster and see what the situation is back there.
4 and 5 will need to come out before you can get access to 6.
Here is what to expect back there.
