elwesso »
https://forums.nicoclub.com/elwesso-u5248.html
Tue Jul 25, 2006 5:45 pm
welcome to NICO bart... im gonna move this to the online mechanic...
put your car in diagnostic mode and we can go from there.. to set the car into diagnostic mode, do this.....
ALL of this is done engine not running.
1. make sure the temp gauge is in the middle (the test WILL NOT work if the engine is cold)2. Put the car in D and set the parking brake (so you dont go rolling). You can turn the key on, shift to D, and turn the key back off.3. While turning the key to ON, hold the trip odometer reset thing to the right (clockwise)... The display should come up with AT CHECK.. If it does not, turn the car off and try it the other way... Regardless, AT check will come on by turning the key on and turning that knob at the same time, i jsut cant remember which way.4. Once AT check is on. shift to 3rd gear, and press the gas all the way down and release it.... Then shift to 2nd, and then to 1st gear, nad then press the gas all the way down...5. The display will pop up the codes... post your codes up and ill tell you what they mean!!
