gazelle_88 wrote:Whats the difference between these and the ones you've shown me?
_trksid=p2060778.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT#ht_1741wt_1397
The link is for a head unit for a 90-93 Q45 and in the 2nd pic you can see the tabs perpendicular to the head unit which tells me that the mounting brackets are still attached. The brackets for a 94-96 are longer since they mount to both the Bose and the HVAC controller. The head units changed for 94-96 so I'm not sure that the 90-93 head unit will work in your Q since I don't have a 94-96 head unit to compare it to. I can get my brackets to you but hold off until you find the correct year head unit as you might find that the brackets are already attached. How is your HVAC controller attached with your head unit missing?
