Postby
Daneo171 »
https://forums.nicoclub.com/daneo171-u215883.htmlMon Apr 07, 2014 8:51 am
Hey Guys Im Trying To Figure Out How To Remove My Alternator Cause As You Guys Kno Its Pretty Tucked Away And Its Low Down On The Engine. My Battery Will Not Hold Charge And On My Dashboard My Slip,TCS,And Air Bag Light Stays ON.So Im Assuming Its The Alternator. Thanks Guys
Postby
elwesso »
https://forums.nicoclub.com/elwesso-u5248.htmlMon Apr 07, 2014 8:55 am
Best way to get to the alternator is to take the battery out, and loosen the AC compressor (don't disconnect it) and then you can access everything pretty easily. It's a 3-4 hour job.
elwesso wrote:Best way to get to the alternator is to take the battery out, and loosen the AC compressor (don't disconnect it) and then you can access everything pretty easily. It's a 3-4 hour job.
