All of the forward gears operate as far as I can tell. While cruising down the highway at 60 MPH the tachometer shows 2200 to 2400 RPM, so I'm hoping that is the correct RPM range for 4th on straight and level and steady speed. The transmission does not seem to be "hunting" gears in forward.
Reverse has engaged a few times, but the letter R on the shift selector is more of a decoration than a function option.
I have been scouring the internet and this forum for clues as to what might be the problem and have read through this post transmission-problems-due-to-neutral-sa ... 51731.html Several times and have pretty much ruled out:
1.Transmission hunting between 3rd and overdrive, not locking up (I need to recheck and make sure.)
2. Reverse Lights Not working (works)
3. Odd Shifting (seems normal in forward)
4. Delayed throttle response (seems ok)
5. Transmission self diagnostic not working.
Not entirely sure about #5 above. The T/A light does flash for about 2 seconds after key is turned initially. Tried to run a test on the diagnostic last night but only saw fast flashes with no flashes of the T/A light longer than others. Looked like a fast regular steady strobe.
Also the gear selector lock button on the shifter will pop up/engage on all gears and P but NOT on Reverse. I have seen this mentioned before in other posts, but no replies as to whether that is a problem, normal, or how to repair.
Is there a way to disassemble the gear shift from inside the car, or a "how to" link?
T
