Cool, thanks for your help.3Q Jay wrote:I'm not in the UK so I can't answer what is avail.
I can tell you that the active ps/wp belt is different than a non-active, non-touring.
this is the active belt as of 3 years ago: BELT, P/S&WP INF#11950-60US5VW, would match the second one in your list with an up-issued part number.
I inherited a set of 3 belts when I bought my base suspension 92Q. They would fit all base 90-96 Q45's. I'm not sure which is which but here's the part numbers:gazelle_88 wrote:..... All I have is from my Nissan dealer which is three part numbers of which I don't know which is which!!!
1172060U01
1195060U05
AY14N40971
Cool, thanks for your help mangoody90q45 wrote:I inherited a set of 3 belts when I bought my base suspension 92Q. They would fit all base 90-96 Q45's. I'm not sure which is which but here's the part numbers:gazelle_88 wrote:..... All I have is from my Nissan dealer which is three part numbers of which I don't know which is which!!!
1172060U01
1195060U05
AY14N40971
11720 60US1 VW
11920 66US1 VW
11950 60US4 VW
Hi Heath,Q451990 wrote:The part numbers I found on http://www.orderinfinitiparts.com are:
1195060US5VW - P/S Belt (Active Suspension)
1192066US1VW - A/C Belt
1172060US1VW - Alternator Belt
http://parts.infinitiusa.com is also helpful to see diagrams, but I'm having problems with their site today.
You mentioned Gates belts being available there. Check out http://navigates.gates.com/Parts.aspx?Y ... enger+Cars for part numbers. The fan/PS belt appears to be the one that varies on active vs. non-active cars. I'm assuming the active uses the "7 ribbed belt" but I'm not sure on that.
Good luck!
Heath
Thanks for your helpBCC93QT wrote:A set of belts for the JHG50/PHG50 or HG50 will work. Your model is a PHG50. Below is a link for a set of belts. Going to have to use a middleman service unless you have a YAJ account. Or you can call any infiniti dealership stateside and order a set of belts for a HG50 Q45
http://page12.auctions.yahoo.co.jp/jp/a ... p443591344
If nothing else, maybe you can source the Gates parts there with the part numbers on their site.gazelle_88 wrote: Hi Heath,
Thanks for your help.
I've checked out their website and tried to place an order but the only country option they provide is the United states
so I've emailed them to see if they'll ship the the UK.....fingers crossed
Thanks
Marc
Q451990 wrote:If nothing else, maybe you can source the Gates parts there with the part numbers on their site.gazelle_88 wrote: Hi Heath,
Thanks
Marc
Good luck!
Heath
