Yes it is better. It doesn't sheer as quickly. I could actually break it down but it's soooo much info already here once you use the search button.Mint Q45A wrote:qship, Q45 Tech,Is synthetic ATF really much better than regular Dexron III? Do you get any noticeable improvements in how the tranny shifts, or is it just more durable? Tks.
Qship,qship96 wrote:Why it is SAFER to take the $120.00 goodyear charges, and go buy 20 quarts of Mobil 1 ATF.......do 6 drain/fills at 3qt each,and use the 19th quart to fine tune level and as spare fluid....take the 20th quart and drain/fill power steering system. Total spent, the same 120, just more wisely
Above procedure will effectivly replace 85+ % of the old fluid with no risk of monkeys damaging your car!
Plus,you will end up with MUCH higher quality ATF this way, as I am sure goodyear uses the cheapest generic atf in order to be able to offer the service at that price
I got the trans flush at a local oil change place. They are a chain, but the have the same management and quite a few of the same employees each time I go there. They were allowed to flush my transmission on the condition I got to watch. I can see how an incompetent and/or untrained person could get contamination in the transmission when hooking up the adapters to the machine.Q45tech wrote:You have guts using a shop not a dealer or independent who specializes in Infiniti.
Much better than all the extra materials, labor and time drain and fill takes. And the fluid is at least 95%- 98% new.mxr662 wrote:
Mine was done with the BG machine after I did a pan drop and filter/fluid change. One BG flush probably would not have got it clean without the prior pan drop.
But what if this shop shows up under BGfindashop? I got mine done at a Sunoco. The Sunoco was listed as a certified BG shop. My Q's been tap-dancing ever since. Bojangles. I spent $150 and it's been ok.Q45tech wrote:You have guts using a shop not a dealer or independent who specilizes in Infiniti.
Over the years we have interviewed hundreds of would be employees, it is scarey beyond imagination!
Over the years we have been forced to try to bring Infiniti's back to life after being destroyed by generic shops.
Exactly how I did mine. I went to one shop and got a pan drop/filter change along with a drain and refill. The next weekend, I got the BG flush.mxr662 wrote:
If one were to purchase the BG flush machine and jump thru a few hoops you would probably get listed on the website. So of the non backyard mechanics here can probably answer that better.Haitian_King wrote:But what if this shop shows up under BGfindashop? I got mine done at a Sunoco. The Sunoco was listed as a certified BG shop. My Q's been tap-dancing ever since. Bojangles. I spent $150 and it's been ok.
Ah, the old Peter Priciple.mxr662 wrote:Maybe that guy has now graduated to transmission flushes.
The fluid is completely seperate. new fluid goes into one side, the old fluid goes into the other side. Nothing to worry about.mxr662 wrote:I still have a concern about contamination in the BG machine finding its way into my transmission.
