Overcamberhttps://forums.nicoclub.com/memberlist.php?mode=viewprofile&u=1131994 Q45 idler pulley dimensions? I mixed them up? please helpSat May 17, 2008 10:07 am
Postby
YELLOW S13 »
https://forums.nicoclub.com/yellow-s13-u32627.htmlMon Oct 03, 2011 8:21 am
Great thank you. I assume all the bearings should be the same then?
My post above was confusing im sorry the seller says 12/37/12 and texas said 12/32/10. So the seller is correct then. Figuring $30 for bearings is better than $60+ for bearings and pulley
Also I just need 4 bearings correct due to 2 on the power steering?
