I have tried to search and Google this, but I can not seem to come up with the answer.
I have a 1994 Q45. I am trying to locate the Consult port. Some posts have mentioned it being behind the fuse panel, but the only fuses I've found at in the engine bay. I've also looked behind the passenger kick panel and just found the ECU. I am truly at a loss for where this connector is located.
Also, on the knock sensor connector on the passenger side of the plenum, I ohm'd the connector on the bottom X's and one was 550k, the other was either shorted or open (it's been a couple weeks).
The pin on the bottom right was the 550k, and the bottom left had nothing. I've noticed the car tends to feel like it's driving through pillows, sort of like the timing is really retarded. Some times it just dances and glides. I wanted to find the consult port to see if I could watch the timing or KS activity while driving.
Should both pins marked X on the picture below be giving me 550k ohm? Are there two knock sensors on a 94 Q? All the injectors were between 10 and 13 ohms.
