definatly not true i have a 92 NA and mine came with bose. the rears were like 4 inch speakers and i dont remember what the frnts were but i had to buy 6.5 speaker brakets from ebay(inclueded front and rear) for liek 30 bucks to fit the 6.5s. now i have 6.5s all the way around and a MA audio 12 sub powered by a 600 watt MA audio amp and a rockford foscate CAP. sounds awesomeaidanair wrote:i coulda told u that.. all 300zx's with bose take 6.5' speakers but u need an adapter or u can make one
The previous owner installed a JVC KD-SX980 receiver with 4 x 50 watt channels and 4 x pre-amp outputs. It is odd that when I removed the cd-deck, I found all 4 x 50 watt wires being used. I expected the two rear bose speakers to be eventually connected to the receiver's pre-amp outputs, since the rear Bose speakers have their own amplifiers. The only thing I can think is that maybe the Bose amplifiers regulated the power coming into them, and thus the 50 watt signal (20 RMS) amplified again didn't make things too distorted? I'm not sure, but I plan on attempting to directly drive the new speaker wires by splicing the blue connector and attempting to use just the speaker wires...or maybe I'll find a connector.big dawg wrote:I assume you are replacing the Bose radio as well, since it doesn't have its own amp. On the Bose system (mine is 1990ZX) each speaker has its own amp. When one of the speakers when bad, I found out that its amp had died and that all the others would probably follow suit very soon. So I pulled them all out, replaced the speakers and radio. I modified the speaker boxes in the doors to fit my new speakers and did similarly the same thing in the rear.Bose was good in its day, but for far less money, I got a far better system.Good luck.BD
Yeah, the stock wires are pretty small. I do have a set of wires already laying around, so I can just use those to route to the back. I was thinking of just connecting the stock wires to make sure everything works okay before I put down new wire.big dawg wrote:I'm no electrical engineer, but I wouldn't think that driving the Bose speakers with additional amps from the deck would be good for either the speakers or the deck, since Bose integrated an amp into each speaker and especially since it uses a proprietary ohm resistance in their speakers, that may be causing the deck to work very hard (overheating) to push sound out of the Bose. You really want to make sure that the speaker ohms match the deck amplifier requirements.You might want to consider laying new wire from the deck to the rear speakers. The only reason I say this is, I tried the splicing route because I dreaded running new wire, only to replace the wires anyway. The sound quality was not very good. Old wires +smaller gauge + higher wattage + lousy connectors=crap sound.Having said that, I really don't think you need to go with super expensive cables like Monster Cables. I think that is more about hype than actual "noticeable" improved sound. I have seen articles that suggest that you will not get any better sound from those types of cables as with any other decent gauge wire cable...especially since the run from the deck to the rear is really not that long.Good Luck.
can you read... i clearly said u need an adapter.. wowskinZ32 wrote:definatly not true i have a 92 NA and mine came with bose. the rears were like 4 inch speakers and i dont remember what the frnts were but i had to buy 6.5 speaker brakets from ebay(inclueded front and rear) for liek 30 bucks to fit the 6.5s. now i have 6.5s all the way around and a MA audio 12 sub powered by a 600 watt MA audio amp and a rockford foscate CAP. sounds awesome
Apparently you can't read. I don't need any adapter to fit any of the new speakers. My rear speakers are 6.5". I don't know what in the hell you are talking about.aidanair wrote:
you don't "need" an adapter but with the ones they sell on ebay you can make it direct fit with perfect alignment and no issues. without an adapter its not as cleanevan_aggie wrote:
I think now I'm only trying to find out why the Nissan wiring doesn't seem to send the power correctly to the rear 4-pin connector.
Exactly. I found a similar item on crutchfield. It lowers the voltage output.EW wrote:If you replace the factory radio but use the factory bose amps and speakers, you need to use an interface to make the aftermarket deck work with the bose amps. That is what the Peripheral SVEN4 was. If you are disconnecting the bose amps and replacing the speakers, then you need to remove the SVEN4 and run directly from the radio speaker outputs to the speakers.
I have a 93 it came with what looks like 4in bose speakers front and back.aidanair wrote:i coulda told u that.. all 300zx's with bose take 6.5' speakers but u need an adapter or u can make one
Hah, like I said... I did thorough searches and many numbnuts kept saying the same thing (ALL 300zxs!!!! pffft ) That is why I was really surprised to find out they were 6.5" speakers.Ryan300zx wrote:
I have a 93 it came with 3.5in bose speakers front and back.
LOL....get that s*** done. If you did the doors then you have the hardest out the way. I dont know about you but i almost cried trying to get that s*** through the doors rubber boot without f-ing the wire up.A Paratroopers 300zx wrote:My 92 TT with Bose had the triangular shaped 4" speakers all around as well. I dremeled out the front boxes and custom fit a 5.25" bracket to each. I now have a stock sealed box in each door that houses Phoenix Gold 5.25" components. I bypassed all factory wiring and ran new wiring properly through the door looms. Plan on doing the same to the rears... sound quality should be great!
Thanks for that. I was speaking for Bose equipped cars only. I should have specified.Ace2cool wrote:The non-Bose systems were 6.5" all around.
Haha yeah I know! It was a PITA, but the easiest way I found to do this was... I undid the black boot over the wire loom on both ends. Then, fed the speaker wire through the door hole and threaded it up the loom with a grabber tool (could potentially use a coat hanger too.) I then threaded the wire through the body hole and into the interior. Sounds A LOT easier than it was... but I didn't want to cut the loom boot or anything like that.dantesdoom wrote:LOL....get that s*** done. If you did the doors then you have the hardest out the way. I dont know about you but i almost cried trying to get that s*** through the doors rubber boot without f-ing the wire up.
And all i will say to this post is that EVERY 300zx i have seen DID NOT come with 6.5 speakers stock all around. But who knows.
You sure about that? AFAIK, all non-Bose systems were 6.5" front, 4"x6" rears.Ace2cool wrote:The non-Bose systems were 6.5" all around.
Technically 4.5", they're very similar to the drivers used in the Bose 901 speakers, but there are over 35 varieties of the "tri-lobe" 4.5" driver (I did a search when I used to work there )Ace2cool wrote:Bose: ~3.5" all around (actually something ridiculous like 3.47" or something like that)
