your G50 is equipped with TCS (see the black motor casing to the left of the snorkel (partially out of the picture frame) in your yahoo photo). Hold your hand on that motor when you turn the key on and see if you feel a 2-way actuation. That would be the TCS secondary throttle plate self check and is normal.94Q45Beast wrote: when the key is turned to "on" position, the car makes another faint awkward hard to describe noise from drivers side for around 1-2 seconds
Voltmeter is good, but you may also need an ammeter to nail what is going on. if it hot wire starts, then something is keeping current from getting to the starter. relay, cabling, ignition switch, etc.94Q45Beast wrote:since my volt meter is suddenly missing, I'm going to hot wire the starter, if it starts then its the relay that's dead, if it doesn't start then its the starter. correct me if i'm wrong please. Thank You
Julius Erving? (The original Dr. J) Well, I'm not a PhD or an M.D. but I'm honored. Just don't ask me to "dunk"--LOL.94Q45Beast wrote: Thank you everyone who gave their thoughts, especially Dr.Jay (if you don't mind me calling you doctor)
