driverdriver »
https://forums.nicoclub.com/driverdriver-u9137.html
Sun Apr 11, 2004 2:40 pm
Re reading your post, I suspect it is your revolution sensor, it usually starts off as an intermittent problem and gets worse. Have you ever pulled the car over, turned it off and restarted it and have had the problem disappear? If it does turn out to be your revolution sensor, I would advise you to get it changed ASAP because it will Kill your tranny. I would also recommend a transmission fluid change right after revolution sensor change to get rid of ahny damaged fluid. Don't have the dealer do it because you need a full vaccumm exchange (dealers only change part of the fluid in there). In Canada Mr. Lube does full vaccum exchanges for about a $100 (Canadian).
Go Leafs Go!!!
