SpecDRacing »
https://forums.nicoclub.com/specdracing-u28175.html
Sat Oct 25, 2008 6:32 am
So more info on the swap. It's taking longer than I'd like, money is tight here lately. I did manage to get the transmission put together. If you are planning on doing this swap, be sure to allow time for obtaining the correct shims. One of the shims I needed to put this together was on back order for over a month! I didn't make the video I wanted to, I just wanted to get the trans put together. So it's finaly all together and ready to be installed into the car.
Few new tips:
The speed sensor from the old trans will fit, will give a signal, BUT does have a slightly smaller diameter than the newer speed sensor. I believe this will not last long, but we will see once it's running. If not, the newer speed sensor is of the same pulse generating type, so it will give the correct signal to my speedo, but the plug will just have to be changed on the wiring harness.
The service manual states, to select the correct shim for the input shaft, main shaft and reverse idler shaft, to subtract the height of the gears from the deptch of the case, then ADD endplay. This is assuming that by adding the endplay, it is written as a negative number. So basically, measure how far into the housing the gears will go (at the bearing, without the shim), and how deep the housing is from its mating surface, subtract the first measurement from the later, then SUBTRACT end play from that. Order the correct shim closest to the middle of the end play range. Example.
D = Distance D1 = hieght of bearing with shaft installed into clutch cover
D2 = depth of transaxle case to where the bearing sits (and shim rides)
Lets say D2 is 86 mm meaning the depth from where the transaxle case bolts to the clutch cover housing, to where the shim will ride is 86 mm.
Lets say that D1 is 84mm and this is measured from where the clutch cover housing bolts to the transaxle housing and measured to the top of the bearing on any given shaft.
D2 - D1 = 2mm That is the gap between the transaxle case and the bearing on that particular shaft.
Now, end play is 0.02mm - 0.09mm. To find the correct shim, you must subtract this from measurement "D" which was 2mm. So to find range you will need to be in, in order to get one shim, you subtract 0.02 from 2.0 giving you 1.98mm and again with 0.09 from 2.0 giving you 1.91mm. Now your shim list gives you shim sizes of 1.90mm, 1.94mm, 1.98mm and so on. You would select either 1.94mm shim or 1.98mm shim. 1.98 will be tighter, but as the trans wears out, this gap will increase slightly. I would use a 1.98 and sand 0.01mm off of it to get just on the tighter side of the middle.
So, thats it for now. I will be putting this in soon and hopefully getting more goodies to install.
The best part of this build is, there arent even that many people on NICO following it, so that means, there won't be many people on the street expecting it!!!!
