Pictures:
This is the two flywheels side by side. Doesn't look like much from here, but trust me.....big differences. For starts, the signal plate is welded on in a completely different clocking position for each. There looks to be a few degrees of difference in the mounting.
Side by side, it is easy to see the two different types of signal plates. One is recessed more than the other. The one on the left is 350z/G35 while the one on the right is for the Altima/Maxima (both pictures).
How to lower the engine. Before I make the timing chain side mount and trans mount, I need to get the height correct. To do this I made longer bolts for the rear and front of the crossmember. These are all available at lowes/home depot. Just find the correct thread/size and length for the drop you need. The white tube is a nylon bushing that makes the smaller steel sleeve fit snug. The larger sleeve then goes over the smaller sleeve. This will fit a little snug in the factory bushings which is ok.
The nylon sleeve might need to the inner wall sanded a bit to fit around the bolt correctly. I used a drill bit and reemed it by hand. I didn't write down the bit size....sorry. The large washer goes on after the sleeve in this case, but should your washer fit the bolt perfectly, then the sleeve will go on after the wasther. I am using washers from the front lower control arms of armadas, titans, frontiers or xterras.
Its a little tight, so using a vice I put the steel sleeve on top, allowing the bolt to pass through and tapped on the bolt untill the metal sleeve was pressed completely against the washer.
How it looks at this point.
Finaly, slide the larger steel sleeve over the smaller one. This one fits loose enough to slide on, but with minimal play. If needed, some epoxy could be placed between these two sleeves to reduce noises. I suspect this might creek a little from time to time. No big deal for me.
The finished pair. Cost me about $10.00 I believe.
The stack of washers are what spaces the member down. You could use uerethane or even hockey pucks if needed, but these fit perfectly and work great. First the bolt will need to pass through the member, then the washers installed between the member and the body.
This is in without the bushings in the member. Only to show the install.
The dark flat piece is the steel plate Im installing on the top and bottom of the radiator support. There are two tubes that will run through the support to keep it from crushing under load. These plates are drilled to the bolt size, and the tubes will not pass through these holes, hence making a ladder like assembly. Keeping the radiator support seperated by these tubes and having the load dispersed by these plates will strengthen the entire lower radiator support. Remember, we will be putting 4 times the hp to the ground with this setup, than its stock box. So little things like this can make all the difference in operation and reliability.
The plate is lying on the subframe here. It will be welded up onto the underside of the radiator support. Again, these bolts, the tubes and these plates were all purchased at lowes/homedepot (either one). These are just longer bolts than the stock ones.
The seperated G35 engine harness (auto transmission harness).
The transmission harness pretty much comes straight out of the engine harness.
Building the subharness for the coils and the injectors. Everything on top of the engine will be in these two harnesses.
The finished injection, coils and IVT subharness. I purchased the wire sheathing and other little goodies for this kind of work from Fry's electronics online. Unless you're lucky enough to live where these stores are, this is the only way to get some of this stuff for cheap.
So that's pretty much it for the pictures. I am a little farther along that this, just haven't taken the pictures. Hope you guys are hanging in there with me.
