S14Dorikin »
https://forums.nicoclub.com/s14dorikin-u32635.html
Mon Aug 07, 2006 4:59 pm
It was blowing fuses before it was rewired. The pump was hooked up to the ecu the way it should have been, but still was blowing the fuse. The way they wired it was so it operates on its own circuit with a relay and directly to the ecu. After they rewired it, the fuse will still blow but the car will still run. So I'm suspecting the Air regulator since its on the stock fuel pump circuit and is the only thing left that runs through that fuse, plus I hear your supposed to change those anyways when you get a fresh swap because they go bad, theres no telling if the previous owner replaced it or not, won't know until I take off the manifold and take a look-sie.
When I drive the car, everything is fine. Just after the fuse blows, the idle will drop to 100rpms when I'm at a stop light or press the clutch, and will pick bacl up to 1000rpms, but sometimes will die out...like I said. Fuel seems to be fine, Air is what I worried about.
