Q45tech wrote:2738 : BG (engine cleaner) quick clean There are probably other products which are just as good but BG makes a complete line for every auto component from spray silicone to AC compressor oil. Oil works by creating a microscopic film which keep the rotating components from actually touching each other. The viscosity (drip thickness which varies with temp)and the surface tension are critical components. When oil gets diluted by gasoline vapors (blowby) the afore mentioned properties are not ideal. When you add a solvent - cleaner to oil to help dissolve carbon build, varnish, and water emulsified sludge you are decreasing its protection while the solvents are in the oil. So always add any solvent when the engine is at operating temperature and leave it in only the minimum length of time and above all don't rev the engine more than is necessary to get from A to B or better don't even move it. Many of the commonly sold PURGE products are too strong for initial use they might free up too much sludge and clog the oil strainer pick up. Easy does it and weak are the safe ways to do it you let it build up slowly so don't try to clean it fast. Most independent shops will carry BG products but the retail mark up is high ($10-$15) also they sell a product called BG MOA which is just Zinc extreme pressure additives in an oil base to protect the bearings from the cleaner just in case! Synthetic Mobil 1 ATF has a lot of anti varnish detergents in it so does regular ATF, years ago it was common to put in a pint of ATF and let the engine idle for 15 minutes and then drain the oil. As you are well aware oil thickens with heat and mileage so the end of its life cycle is when you want to add the cleaners but unfortunately the oil filter is probably plugged and in bypass already by 3-4,000 miles depending on engine condition. So the first time do it at 2,000 miles. Quick Clean is nice because more than 50% of it evaporates in 15 minutes at normal oil temperature, again a self protecting mechanism. Expect to clean 2-3 times easy then progressively harder to get 80,000 miles of gunk out of an engine if you use standard oils. An interesting thing would be to use Brake Part Spray Cleaner which evaporates almost instantly in the oil drain hole after the oil has drained out to attack the oil pan varnish and free up more crud. Hold on to the spray tube as I have 2 in my oil pan now! The pricey Mobil 1 oil filter seems to keep oil cleaner for 500 miles longer than the OEM but doesn't really filter the microscopic particles much if any better after 1500 miles.Varnish Removal Varnish is a clear to dark amber hard layer that results from volatile gums and resins depositing on relatively cooler engine parts or where there is little oil flow like valve covers, in the hydraulic valve lifters, camshafts away from the lobes and bearings, valve springs, crankcase walls, inside pistons, etc. It may or may not be sticky, depending on the engine temperature history when the varnish was deposited. HOW TO AVOID VARNISHDetergents in the oil will generally always keep high flow areas clean and changing oil regularly will keep them from depositing anywhere. Fuel quality is the single biggest factor in determining how much varnish an engine will generate. Buy good fuel which advertises 'keep clean' or 'clean-up' additives and you will go a long way to preventing varnish build-up. HOW TO CLEAN UP VARNISH DEPOSITSWe need a POLAR solvent like alcohols, ethers, ketones (like lacquer thinner!) all of which will dissolve the 'varnish' into the liquid mixture of oil and 'solvent' which can be flushed out with the oil drain. There is a wide array of commercial products available at auto parts stores containing combinations and mixtures of alcohols, ethers, ketones, and similar chemicals, all of which will work. Read the labels. 'Petroleum Solvents' do not work very well for varnish deposits. STP has an excellent product which includes additives protect the critical surfaces from oil film failure. It is also less volatile than most varnish solvents so it can be used longer in hot oil without risk of re-depositing the varnish. The important thing to remember is temperature and time of effective use. These varnish solvents generally are quite volatile and will evaporate out of hot oil quite quickly. They should used with a fresh oil change of 20 Wt. Add the solvent in cool engines, run it a few minutes to circulate it and get the oil hot (20-30 min). Shut it off and leave it soaking over night if possible. In the morning (or after as much soaking time as you can spare during the day) restart the engine and run it to hot again (20-30 minutes should be plenty)and then drain the oil, change the filter, and refill with regular oil and go on your way. DO NOT use gum and varnish solvents in a HOT engine with dirty oil and keep on driving because you just move varnish around--dissolving it at first with the solvent, and then re-depositing it as the solvent evaporates out of the hot oil. It may actually make the problem worse because the 'problem area' is just that because it tends to collect varnish deposits faster or is more critical in the first place. The solvent will work slowest in the most difficult areas, and newly dissolved varnish will re-deposit in the most deposit prone areas. DO NOT add more of the solvent than recommended. Too much solvent weakens the oil film strength and may allow metal to metal contact with unpleasant consequences. Do not drive the car or race the engine until you refill it with fresh oil. NOTE, avoid 'routine' use of these varnish solvents because they ARE very aggressive and can attack plastic parts (like the Q timing chain guides) and cause cracking. I suggest Q owners use only the STP engine flush product or Marvel Mystery Oil (see below) unless they are desperate. I have seen the lab testing on the STP product and it does perform very well indeed. I have over 45 years of good, no-problem experience with Marvel Mystery Oil, but it works slowly compared to these aggressive 'solvents'. Q45tech recommends BG products based on his many years of their successful use. That good experience is worth considering strongly. I do not have any experience with them however. I use Mobil 1 10w-30 a splash (3oz) of Zinc (BG MOA 11oz can) and change at 3500 with stock OEM filter. Something like BG Quick Clean (kerosene like) every 10K will remove varnish. Most modern oil formulations have removed or greatly reduced Zinc additive because too much and oil burning can poison cat converters.
Front crank seals on Q seem to actually last longer with full synthetic (70k vs. 120K). Don't you think 15w-50 is a little heavy even for Texas (your Varnish?).The trick is to keep the Viton valve stem seals clean so they won't wear. Why you see so many smoking Q with only 150k.
10 HP or 10 lb./ft of torque more is worth about 0.05 seconds in 0-60 or 0.1 secs in quarter. So 3 may be unmeasurable. What we really need is a new air box with more filter area, but where would it fit--double area =1/4 resistance. The Q never needs more than 350 cfm @ 4,000 or 380 cfm @ 6,200 rpm. [274 cu in/2 x RPM] divided by 12x12x12 or 1728 = raw CFM x volumetric efficiency [110%@4000 84%@ 6000]. Keep reading and I promise in 90 days you'll wow your friends and GM engine designers. Please take the time to read the 24 installments of
http://www.performanceprofessor.com it's a nice break from work.
There are probably other products which are just as good but BG makes a complete line for every auto component from spray silicone to AC compressor oil. Oil works by creating a microscopic film which keep the rotating components from actually touching each other. The viscosity (drip thickness which varies with temp)and the surface tension are critical components. When oil gets diluted by gasoline vapors (blow by) the afore mentioned properties are not ideal. When you add a solvent - cleaner to oil to help dissolve carbon build, varnish, and water emulsified sludge you are decreasing its protection while the solvents are in the oil. So always add any solvent when the engine is at operating temperature and leave it in only the minimum length of time and above all don't rev the engine more than is necessary to get from A to B or better don't even move it.Many of the commonly sold PURGE products are too strong for initial use they might free up too much sludge and clog the oil strainer pick up. Easy does it and weak are the safe ways to do it you let it build up slowly so don't try to clean it fast. Most independent shops will carry BG products but the retail mark up is high ($10-$15) also they sell a product called BG MOA which is just Zinc extreme pressure additives in an oil base to protect the bearings from the cleaner just in case! Synthetic Mobil 1 ATF has a lot of anti varnish detergents in it so does regular ATF, years ago it was common to put in a pint of ATF and let the engine idle for 15 minutes and then drain the oil. As you are well aware oil thickens with heat and mileage so the end of its life cycle is when you want to add the cleaners but unfortunately the oil filter is probably plugged and in bypass already by 3-4,000 miles depending on engine condition. So the first time do it at 2,000 miles. Quick Clean is nice because more than 50% of it evaporates in 15 minutes at normal oil temperature, again a self protecting mechanism. Expect to clean 2-3 times easy then progressively harder to get 80,000 miles of gunk out of an engine if you use standard oils. An interesting thing would be to use Brake Part Spray Cleaner which evaporates almost instantly in the oil drain hole after the oil has drained out to attack the oil pan varnish and free up more crud. Hold on to the spray tube as I have 2 in my oil pan now! The pricey Mobil 1 oil filter seems to keep oil cleaner for 500 miles longer than the OEM but doesn't really filter the microscopic particles much if any better after 1500 miles.
