Zwicked »
https://forums.nicoclub.com/zwicked-u65277.html
Thu Apr 17, 2008 5:22 pm
Run some Seafoam in the engine oil for 100 miles before your next oil change, and then use a good 5 or 10W30 synthetic. Often that helps.
You probably don't have low oil pressure. It's famous for the pressure transducer's hole to plug up and read incorrectly. You can remove it and try to clean the tiny hole, or buy a new one for under $100
