Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Sat May 11, 2013 11:57 am
Ah, then try bleeding it. Also see if there's any fluid leaking from the slave cylinder.
Wait, are you saying it tries to turn over and can't, or it won't even try to turn over?
If it won't try, the switch has an adjustment. Just climb up under the dash and adjust the switch. It'll be pretty easy to figure out.
If it's trying and can't turn over, then do bleeding and inspection. Also, the clutch pedal has an adjustment rod on it that connects the pedal to the master cylinder.
