Thanks to everyone who has said this is a nice build
Lot more work involved than I initially though when i decided to get into a 240 lol.
Small update, been troubleshooting this damn thing for awhile -.-
So it started and ran ok, then a fitting i had welded on one side and threaded into the egr hole in the downpipe (i think egr lol) fell out on the highway drive.
The next day i realized my brake lights werent working, it was the sender unit on the pedal, easy fix. Went to have the hole welded and about 500ft from the shop my front brakes locked up....i pulled into the parking lot and had a good amount of smoke coming from my front tires. They shop owner (it was a menieke) was a 240 fan and he fixed my brakes in like 2 mins, cant remember what he said he adjusted but they work
Ok, so my car is about 5mins from being done and my fiance pulls up to go to lunch, i leave my car there and when i come back the damn wont idle -.-. I start it, have to give it a little gas to keep it from dying, which made stop lights tricky haha. Was able to get it home and toyed with the IACV and throttle cable, got it to idle fine, not sure what RPM because still trying to figure out my tach/speedo issue, but it sounded good haha.
So i took it around the block a few times, it drove good, shifted good and then I go to pull out onto a main road and it sputters. I pump the gas and barely get it into a parking lot about 30feet away...sit there and the idle sounds find. I drive it around the parking lot and its driving fine again -.-, i go to try this main road again and it does the same thing...WTF. I get it home and let it sit overnight. At this point I was frustrated and didn't feel like messing with it.
I noticed a vacuum line going from the intake to a hardline to right/bottom of the throttle body collapsed when the car was on, so i figured that was the problem. Went and got a new hose and new air filter since mine did not fit right. Started it and tried to take it around the block and it died about 50 feet down the road....I had to push it back into my drive. Now it will sttart and immediately die, i mean you can hear it combust and then poof, dead. I have spark, the timing is correct, the injectors have been tested and its a brand new fuel filter and new fuel soooo now im waiting on my Walbro 255 fuel pump to be delivered...hoping this fixes it -.-
Got bored and just took some more pics, nothing new
