white90esex »
https://forums.nicoclub.com/white90esex-u35623.html
Thu Feb 19, 2015 10:40 pm
Read up on the clutch adjustment and the stop adjustment so ill try that stuff in the AM. im tired.
Anyway, right now what im looking at is the sunroof was in the car, closed. It popped up just fine, no problems at all. closed it. then slid it all the way back. Then tried to close it again, now its coming up about an inch short from being closed. kinda odd. Im not too concerened cause ill get it sorted before I ever drive this car.
Also, what seems to be more concerning to me is the function of the switches. So there are two switches for the sunroof?? What mine is doing is I have to use one switch to slide it back 1/3 the way. Once it stops then I use the other switch to continue it on its journey. Same with closing it. If its fully open I hit one switch to close it part way, it stops on its own. then I use the other switch to continue it and it isnt closing all the way.
I bought this car years ago and ive just been wrenching on it slowly over time. Never once opened the sunroof until today in the garage while working on it. So I have no comparison to how it worked before or how its supposed to work.
