PapaTom »
https://forums.nicoclub.com/papatom-u132241.html
Tue Apr 28, 2009 9:45 am
Well, everything is in the car and entire engine bay and undercarriage was steam cleaned. It starts but runs kinda sluggish and idles rough. I'm not sure where to set the timing. The Chiltons book say 20 degrees BDC, but indicates the notches on the lower dampener are 0, 10, 20, 30 and 40. When I had set it to TDC when changing the timing belt, the camshaft sprockets, crankshaft sprockets and rotor were pointing to TDC when the timing indicator was at the 40 degree mark. When I installed the new timing belt nothing moved and everything was assembled in reverse order to ensure nothing was out of place.
Now I'm stumped. It starts, idles, accelerates slow and sluggish no matter where I set the timing mark. I'm going to check the vacuum lines again. I may have missed something.
