ricebike wrote:
way to go.. but like i said, ECU didn't throw a speed sensor code?
It's the oddest thing, but no it never did. I'm told that if the speed sensor fails AT ALL it should throw a code that is stored in the ECU. This code SHOULD NOT be cleared if the speed sensor begins working again, correct? It was the first thing I checked before replacing the instrument cluster. But, no speed sensor errors.
That's what led me to replace the cluster... only to find out it wasn't the problem. I still can't figure why the ECU didn't report anything. Maybe that's going too. But so far, no problems. I am happy.
xn7 wrote:did you have to drain the tranny it replace the sensor? any pictures for the FSM-less? or where can i view the FSM
I didn't HAVE to drain the transmission to replace it, no. Would have been less messy, though, and would have saved a rag. But this was far quicker. hehe. I quickly pulled it out and stuck my thumb in the hole with a clean rag (pan underneath to catch anything I missed). I couldn't stop it up, so I had my brother (who was working on his car at the time -- Leatherique is impressive stuff) crawl under and plug it up while I worked the sensor. There's a red plastic gear cap on the end with a clip that needs to be transferred. Then, popped it back in. Didn't loose much fluid, but I "topped her off" anyway, just to be safe. Eyeballed what I lost and replaced it by taking out the shift knob.
I'm not ready to change the transmission fluid anyway, yet. At 138,000 miles, and as far as I know it's never been changed, I'll do it right by changing the filter, oil, driving it for 1000 miles, and then doing it again. I hear all sorts of horror stories about changing the fluid in old transmissions.
I'll get some pictures for you when it finally stops raining out here.
BTW, the FSM is available in pdf from a sticky in this forum. Or you can search for it on google.
rogoman wrote:Check out the speed sensor at the back of the tranny; the harness connector may have a problem.
Check that too, actually. I'm using a speed sensor from Advance Auto which cost $80 (Nissan Dealership wanted $185 for theirs). So, if I didn't have to use it, I didn't want to since I want to do some front end suspension work. Connector was fine and clean. I still have the old sensor. Plan on trying to get into it to see how it works.
Who would want a used speed sensor that has problems in hot temperatures anyway?
