mtcookson »
https://forums.nicoclub.com/mtcookson-u3042.html
Thu May 24, 2007 6:49 am
Each speaker in the Bose system has its own amplifier and these amps tend to die. The best way to fix the issue would be to put in some new speakers and an aftermarket head unit.
If you go that route, you'll want to bypass the amps and wire the speakers directly. There are 4 wires total at each speaker, the two larger wires are the power wires for the amp and the two smaller are the signal. Just cut the two signal wires and connect those to the new speakers.
