hessianben »
https://forums.nicoclub.com/hessianben-u49684.html
Wed Jul 30, 2008 9:59 pm
The hubs have the same dimensions, and no, the Titan wheels will not seat properly as is.... However, you can easily use a router and remove a groove of material from the hub opening on the wheels, or, if you're not concerned with tucking your tires inside the fenders- you can order aluminum adapters 6lug to 6lug, which will widen the truck's stance, and clear the hub. You will need at least 1" thick adapters to clear. I run 2" all around, and it works great!
... and you can find em for cheap!! I've got another set in Socal for $300. (no shipping sorry!)
