ml21 »
https://forums.nicoclub.com/ml21-u173594.html
Thu Apr 14, 2011 3:39 am
Well guys i have a 2001 pathfinder 4x4 93,xxx miles and when its in park and your rev it inbetween 1500-2000 RPM the truck surges up and dow between 1500-2000 RPM basicaly like its hitting a rev limiter/fuel cut but if i rev it higher it has no problem? only dose it in park or neutral and when in drive truck drives fine.... Dont kno if related but gas mileage has gone down and when in drive some times i can feel the motor slighly miss while on the brake at a light. As far as matinence goes i have recently changed the fuel filter, engine oil, belts(both), front and rear diff fluids, coolant, power valve screw issue with new gaskets,valve cover gaskets, and seafoamed engine(By the intake not oil). my tune up was done at 60k(spark plugs) and problem is still present. Has anyone delt with this issue before if so i could please use your help thank you.
P.S- i forgot to add that it did have the rear o2 sensor code stored with out ses light being on for one of the rears which was explaind by a tsb on here if that matters.
