brianmcw09 wrote:Appreciate it. I'm not looking forward to some of the maintenance that has to be done to my I35, it's probably getting garaged in the next couple weeks so I can work on it at my own pace. Currently needs valve covers and valve cover gaskets, coil packs, engine mounts, and a few other small things done - as well as the tires.
Honestly, most of this stuff isn't that bad. Engine mounts are very simple...all you need is a floor jack to support the engine and a wrench to loosen the bolts. The mounts are easy to reach and very simple to remove. Valve covers and gaskets aren't that tough either (though you'll have to remove the upper intake manifold to get to the rear). And aside from cost, coils will be cake while you're under there for the valve covers.
Really, the I35 shouldn't be expensive to maintain. It might be a luxury car, but it's not a BMW, or even
really an Infiniti. It's a very solid car mechanically, without a lot of electronic garbage, and relatively problem-free. I seriously doubt a Corolla would be any cheaper to own. This isn't some 7-speed V12 luxomonstrosity. If you're willing to do the work in your driveway, you shouldn't be any worse off than with any "average" car. There's really nothing particularly complex or abnormally expensive on the car. I don't say this to be contrary or argumentative, but as reassurance. Don't be too worried. We can help you keep the car affordable to own.
As AZHitman noted, the I35 is really just a Maxima. The only differences are some body parts and the clock trim on the dash. All other parts can be sourced from a Nissan dealer, and Nissan dealers are equipped to service the car. So you can probably save some bucks there.
If you're really looking to save money on tires, don't forget about the used option. Quality is very hit-or-miss, but it's worth taking a look at what various tire shops might have on hand. Used tires are extremely cheap, so even buying 2 or 3 sets to equal the life of a new tire can still end up being cheaper.
brianmcw09 wrote:Just picked up a second car (won't mention the brand/model for fear of beatings lol)
No beatings, don't worry. We might be a Nissan site, but we're all car enthusiasts here.
