Chuck Tribolet »
https://forums.nicoclub.com/chuck-tribolet-u120862.html
Sun Mar 07, 2010 8:50 am
I got the project installed in the truck this morning.
Note: this was done on a 2001 Pathfinder SE. Your details may vary wildly,or not at all. Measure twice (or more), cut once.
The ceiling console is held in with one phillips-head screw inside the sunglassescompartment, and four metal clips. Remove the screw, then pop off the ceiling console with a gasket scraper or stiff putty knife. It will then dangledown on three cables. Disconnect the three plugs by pressing in on the release tab with a small screwdriver. Trace the wires from the compass unit.The wires on the compass side are all black, so check the color code at thecorresponding truck-side connector. In my, green with red stripe was 12Vswitched with the ignition, and black was ground. Mark the compass-sideconnector. I used red and black Sharpies.
Now take ceiling console to a comfortable place to work. The plug is securedto the ceiling console with a phillips head screw. Remove the screw, and carefully trim away about 3/8" of insulation on the 12V and ground wires, wrap the wires from the USB plug around where you stripped, and solder. Here's what it will look like:
Now wrap the solder joint with about 1.5" of electrical tape running the longway along the wire. This is called a cigarette wrap. Here's what it will looklike:
Now put it all back together.
Reattach the plug with the phillips head screw.
Tape the USB cord to the USB charger with some electrical tape. You can route the cord out the area around the rear-view mirror. I tucked the cord behind the head liner over to where the sun visor pivots, took a couple of loose turns around the sun visor pivot, the across the leading edge of the sun visor to the hands-free unit.
There's about an extra foot of cord bundled on top of the sun visor that I'llprobably tuck inside the ceiling console sometime, but first I need to figuresome sort of nice clip to secure cord along the leading edge of the sunvisor.
Chuck
