I just thought that would be a bad thing, to basically ground your positiveDattebayo wrote:He means after the battery has been completely disconnected from both the red and black clamps, touch the clamps together.
There is no real polarity if the battery is disconnected.CanuckQx4 wrote:I just thought that would be a bad thing, to basically ground your positive
I checked some FSMs, and that works for ODB1 and 2, but you have to turn it all the way and then back twice.brizanden wrote:im almost postive if you turn the adjuster screw on the ecu all the way to the right or left (i forget) it resets it. and the other way is diagnostic mod.
