No problem Audtatious, will do! I have seen a few threads myself with similar issues and coming to a cliff-hanger without knowing whether / how the issue was resolved. The link to the FSM has been helpful so far thanks.
I removed the dust-cover on the bell housing and could see fluid leaking from the Slave (I topped up the clutch fluid to check for obvious leaks). It doesn't appear to be as big a job as I thought for dropping the transmission to replace the slave cylinder and with $$$ constraints at the moment, I am going to go with just the Slave and not the Clutch-Pack considering that I am not paying for labour.
The Master does seem to be ok however the fluid that I had topped up is a dirty black colour now in the reservoir...which has obviously tracked back from the Slave, through the master and into the reservoir, because of this I am going to change the Master Cylinder also to be on the safe side.
I'll be doing the work this week so I'll keep you posted if this works out. Thanks for the interest.
Links:
OEM Master:
http://www.zspeedperformance.com/Nissan ... -jk00b.htm
OEM Slave (cheaper here than most sites I found):
http://www.zspeedperformance.com/Nissan ... 1JK40D.htm
OEM Slave Pipe Assembly (recommended in the FSM to be changed whenever the slave is changed):
http://www.zspeedperformance.com/Concen ... -JK40A.htm
