azkid wrote:The high beam light on the dash does come on. But as previously stated nothing happens with the headlights. I did look under the hood at the fusebox and noticed that there is one spot not filled. It is labled as FL40A H/L Washer. The only problem is that the slot only has one pronge. So I can't test it to see if this is my problem. What do you think?
I think that option is available in some countries.
Did you pull out any of the headlight fuses and look at them? There are four fuses associated with the headlights, two (15 amp) each which are for the headlights themselves and two (10amp) each for the high beam solinoids. Your combination switch tells the BCM (body control module) what to do in the way of headlights. The BCM then sends a message to the unified meter and to the IPDM (intelligent power distribution module) via a set of data lines. This is why I asked about the high beam indication. If the high beam indication follows the position of the switch, turning on an off when you push/pull the high beams and going on/off when you turn the headlights on an off then the switch may not be the problem. This also is pointing to the fact that the BCM may well be ok.
When the signal is sent to the IPDM then it will turn on the headlight relay and also will control the high beam solinoid as needed through that relay.
So now if you pull the fuses and they look ok you should be able to put a meter on the high side of the fuse and since this is connected to the relays which are connected to the battery you should be able to pick up a 12 volt reading with the headlights on and the high beams on (as indicated on the unified meter) on all 4 fuses (just make sure you are on the high side of the fuses). If you can't tell which is the high side then first test for a 12 volt reading on both sides of the high beam solinoid fuse. If both sides don't give a reading then check for continuity to ground as one side of the high beam solinoid is grounded. The side that gives you continuity (assuming the solinoids are ok) is the low side of the fuse (you want the other side to check for 12 volts and the fuses are probably orientated the same). If these points follow the switch requests then both the BCM and IPDM sound like they are ok.
If this is the case then you need to move to the headlights if the fuses are ok. I am not sure in this case as far as the ground goes, but it appears that they have their separate grounds, some cars use a single ground for lights so make sure the headlights are grounded. Then you need to check the power at the headlights to the HID. Again not sure what the connectors look like on the assembly but the power to the HID is pin number 5, the power to the high beam solinoid is pin number 7, and the ground is pin number 3. These may not be pins but these are the numbers for whatever the connector actually is.
Have fun.
Perry
