So, I’m back with yet another issue. I was driving home from work one night in some heavy rain, and my car was fine until it got to 4th Gear. It just revved and did nothing else, like the car went into neutral. I pulled over, turned it off and turned it back on. As I’m leaving the parking lot, I feel the car struggling to accelerate and then my check engine light pops up. Luckily I was right in front of an autozone, so I had the codes pulled.
They pulled up P1757 and P1759. So, of course I did my research and found it might be an issue with the brake solenoid. Great. I dig deeper and found there’s a easier way to go about this fix. A pin inside the TCM might have snapped causing the “limp in mode.” So I drive the car home, let it sit over night.
Next day, I attempt to drive the car to the mechanic. Get in the car, head towards the exit for my neighborhood, and I hear a VERY aloud whine, and the car just began to rev again. I try to throw it in reverse... nothing but the noise. Drive. No change in RPMS. Just the noise.
So I was able to push it into a parking spot and put it in park. The noise continued while in park but died out eventually.
Here’s a video for reference.
https://youtu.be/wvzkyX41Kb0
Can someone PLEASE help me? I’d greatly appreciate it.
P.S. it’s an 06 Base with 163,XXX. I don’t know the cars service history so not sure if it had transmission work done in the past.
Thanks,
Marquise
