loystock »
https://forums.nicoclub.com/loystock-u10145.html
Fri Jul 17, 2009 4:24 pm
The car, an 03Q with 56K miles, had no problem until I did the Throttle Body cleaning. As part of preventive maintenance, every 2 years, I clean the TB, ATF fluid exchange, brake pads check & fluid flush, gear oil change, P/S drain and refill, radiator flush, etc.
After taking out the air intake duct, the I found out the TB was still very clean but cleaned it anyway. Then I removed the connectors besides the TB (Throttle Control Actuator), cleaned with contact cleaner and then applied dielectric grease. Drove the car for a couple of days fault-free, then CEL came on with DTC P0507-Idle Speed Control problem (more than 25RPM over programmed Idle RPM). Per FSM, problem could be with Electric Throttle Control Actuator; Intake Air Leak; or PCV System. I disassembled the intake duct, checked for any leak source and re-assembled. Per FSM, RE-LEARNING is required any time the Throttle Control Actuator or ECM is disconnected, duh. I did the Gas Pedal and Throttle Valve Closed re-learning and then IAVL (Idle Air Volume Learning). Per spec, Idle at Park/Neutral and NO LOAD should be 650+/-50 RPM. Although the CEL came off, the lowest I can get was 750 RPM. I drove the car for several minutes then as soon as I parked, CEL came on again, same DTC code.
From internet search, I found out that this is a common problem (IAVL Fail due no-load Idle >725 RPM)) with 2002-2005 Nissan and Infiniti - Nissan TSB NTB05-067 and Infiniti TSB ITB05-042. On another Infiniti forum (not NICO) a member posted that it can only be corrected by ECM re-programming, $200 at dealership. Really???
Is there any one who has a complete copy of the TSB? Should I bite the bullet and take it to the dealership? I know my PCV is good but I will replace and re-check before going to the dealership.
Modified by loystock at 4:13 PM 8/10/2009
