Dachristianman »
https://forums.nicoclub.com/dachristianman-u62413.html
Tue Apr 08, 2014 4:18 pm
Here are some additional notes on replacing the starter. The top starter nut is the biggest pain of the entire job. It is nearly impossible to get to and very hard to break free. In order to get to the top 14mm nut, you'll need to go in from the front of the engine, right behind the alternator with a long extension (or multiple extensions). You'll need to feed the 3/8" extension past the motor mount, and then figure out a way to get the socket onto the extension after it's close to the nut. (There isn't enough clearance by the motor mount to allow the thickness of the socket to pass through). I used a piece of thick wire and taped my socket onto that and fed it up to the nut using a mirror to see what I was doing. It worked, but it wasn't easy. Also, in order to get the starter out, you'll need to remove the lower nut from off of the motor mount and using a jack, lift the motor about 4 inches. That is the only way to get enough clearance to get the starter to come out.
After doing this job, I think I could do it again in about an hour or so, but it took me about 4 hours because I didn't know how to get to that top nut. Also, if you're experiencing the clicking noise, but the starter won't engage, try cleaning all the connections on the starter without removing it from the vehicle. It could be that your contacts are corroded. I couldn't find any evidence of issues on my old starter when I pulled it out aside from some corrosion.
Good luck on the job. By the way, I found a used OEM starter for $40 shipped. We'll see how long it lasts, but if I get a couple years out of it, it'll be worth the $900 saved by not taking to the dealer.
Tom
