Jabberwocky »
https://forums.nicoclub.com/jabberwocky-u184885.html
Sat Feb 02, 2013 2:23 pm
2002 Sentra SE-R Spec V, 160k miles, only mods are a JWT Popcharger, Apexi N1 catback, Centerforce clutch & Kenwood head unit.
These problems have been going on for a couple months and I have tried to figure it out but I am coming up with nothing. Since I bought it about 2 years ago I would get occasional hard starts. Crank, turn off the key, then crank again and it would start. About a week ago it started an erratic idle and after warming up would stall at idle. I replaced the fuel pump with a new Bosch unit and it runs fine again and took care of the hard starts. I never got any CEL until I replaced the fuel pump, now it is throwing a code for Fuel Temp Sensor Circuit High Output.
At times I also get either static or a whine that gets louder as the RPMs increase in the passenger front speaker. I have checked the wiring to the head unit and all of the connections are good (I soldered them when installed).
Also, occasionally my headlights, taillights, and interior lights dim & brighten, usually only when the electric fan kicks on.
I have replaced the negative battery cable and cleaned the spot where it bolts to the inner fender. The positive battery post has turned black, I thought maybe it was arcing so I had someone start it at night while I watched but didn't see anything. The battery and alternator both test fine. Months ago I found a ground wire from the transmission to frame was barely hanging on, so I made a new ground wire and replaced it.
My questions are:
1. What could be causing the CEL with a brand new pump? I am assuming the temp sensor is part of the new pump assembly, so could that just be faulty from the factory?
2. What could be causing the static/whining in my speaker & the lighting dimming/brightening?
3. Anyone know why my positive battery post would be black? I've never seen this before, so I am not sure what would be causing it.
4. Could these problems possibly be attributed to the same source, or am I overthinking it?
Thanks in advance for any help, its really just a nuisance right now but I don't know if it could be something that could cause bigger problems in the future (fried ECU, electrical fire, etc).
