downforceus wrote:My '02 Maxima seems to rev alot higher than anything I've ever started before (only for the 1-1.5 seconds after I turn the key) The part of this issue that perplexes me is that there is a rattling sound at the end of that rev. The sound seems like it's coming from the top of the motor and not where I first assumed it was coming from(exhaust shield). I've taken this car to my Nissan dealer twice. The first time they reprogrammed the computer and cleaned the fuel system. It did the same thing when I brought it home. I took it back and they said it could possibly be the fact that I had a non-Nissan oil filter in it. They said that the Nissan filter has some kind of valve in it that would do a better job of keeping the oil pressure up at restarts. As far as I know, all oil filters have this valve. Anybody have any suggestions? thanks
If I were you I would consider this rattling noise normal. We have Variable Valve Timing and a timing chain, and when the engine is started cold, the VTC sprockets are not properly lubricated, thus making a rattling noise. There's a TSB out for it which entails replacing these VTC sprockets and I had it done but the noise came back in about a month...just deal with it. It's not harming anything, it's just a slight annoyance. And it revs to around 1500 to build oil pressure...again, it's completely normal for the FWD VQ35
