Side note, I actually ran an oil analysis test (
http://www.blackstone-labs.com/) to see if I could run my car longer between oil changes. I was sticking to 6k-7.5k between oil changes. After running the tests, the comments on the report said since the (regular) oil still had some life left and I could run my 02 I35 10k miles between changes, but that I should probably stick to 7.5k to be on the safe side. My car currently has 145k miles and I don't use high mileage anything.
Just my two cents
