01 QX 2wd Rear U-Joint DIY
PogiQX
Car: 2001 Infiniti QX4
Hello. Got a confirmation that I will need to replace the rear U-joint.....calling all expert on this area. I looked at the service manual pdf and couldn't find the info (a bit confusing) on how to simply replace the U-joint
How hard and what is the process? Could someone point me in the right direction please. Is this a simple DIY? I ordered a new GMB rear U-Joint already and ready to tackle it this coming weekend. Thanks
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
On every other Nissan I've seen the U joints are not easily replaceable. I was in a similar situation, and I ended up taking the driveshaft out and had a shop put in new U joints and check everything else out..
PogiQX
bump...
anyone replaced theirs on their own?
