Hey guys I've been lurking on here for a few months, Not really a poster, but i had a question i can't seem to find an answer to. I have a 2000 Q45 base model 4.1(sadly
). Along with many others i too have pulled the horrible p0400 EGR System Problems code, As i have read many clear it with simple cleaning and some have to do a great deal more. I, sadly, happen to be the latter. Since i cannot do the work myself due to not having the space or tools i take it to a mechanic that i somewhat trust. Before just throwing money at it i had it cleaned, the egr and tube, didn't fix it. I first replaced the EGR unit itself(looked like it was 14 years old so i replaced it, was about 200$) That didn't fix it. Replaced the EGR control solenoid( i read threw the FSM a little, provided by you lovely people
, that suggested the EGR-C solenoid about 120$) That hasn't fixed it. I believe when it was cleaned the vacuum lines where checked, i obviously don't know, but someone recently posted that that fixed their problem. Does anyone have any suggestions for me to do? Also does this code give any drive ability issues? Besides the p0400 code i also am getting a p0330 Knock sensor, bank 2 and a p0140 O2S high voltage. Checked the O2 voltages with the OBD2 diagnostics thingy the O2 is completely shot, sitting at one steady number instead of fluctuating like the others. Any place to find a couple of OEM O2 sensors? ones i found online(unsure of the site) are like 140$ a piece for the rear ones and about 125$ for the front ones. Could the KS code give drive ability issues? i assume the O2 code would give some issues, since its jammed at one level. I recently also got exhaust work done, half de-cat with straight 2" to two Magnaflow performance mufflers. sounds good other than the rough running due to the above. Anyway thanks in advanced for any input. Won't be upset if noone cares either.
