The P0420 problem is most likely the Bank 1 Pre-Cat (below the engine) or the related O2 sensors. You may have SMOG Check issue with the y-pipe so check your state emission requirements.
I almost forgot, there is an Infinti Technical Bulletin that covers P0420. It may involve reprogramming of the ECU (due to mis-diagnosis) OR replacement of the Pre-Cat and front O2 sensor, depending on the part number of the ECM. Refer to the link below.
http://ww2.justanswer.com/uploads/badda ... 0-054b.pdf
You have a 10-year old car and parts will likely fail as time goes by. A lot of components are rated @ 100K miles - plugs, O2 sensors, etc. Even Federal Emission warranty is only for 8 years/80K miles. Suspension components are typically replaced @ 60-90K miles.
The Maxima/I30 have better than average reliability. So as long they are properly maintained, they should last beyond the current average lifespan of 12 years/128K miles.
So you have had Bank 2 Pre-Cat (P0430) replaced last year and this time you have P0420 (Bank 1 Pre-Cat). Bank 1 refers to Cylinders 1-3-5 (close to the firewall) while Bank 2 is for Cylinders 2-4-6 (front of the engine, towards radiator). Bank 2 Pre-Cat is visible from the front of the engine while with Bank 1 Pre-Cat, you have to safely jack up the car (pax side) as it is under the engine.
The 3-way Pre-Cat and Main Cat, aside from oxidizing/reducing harmful CO, HC and NOx into less harmful gases, also store oxygen. In the 00 I30, each Pre-Cat has a front (upstream) and rear (downstream) O2 sensors. There is no O2 sensor in the main cat. The ECM controls air-fuel mixture as a function of throttle position, mass air flow, front O2 sensors, etc. Normally. the O2 sensors 'see' air-fuel mixture switching from lean-ideal-rich and so on. Due to to O2 storage capability of the 'cat,' the rear O2 sensors switch slower than the front O2 sensors. But if the Pre-Cat is worn out (unable to store O2), then the rear O2 sensor switch rate approaches the front O2 sensor switch rate. At a certain threshold, the ECM flags a failing 'cat' (low efficiency) and generates the fault code, P0420 or P0430, etc.
From my experience with Nissan/Infiniti cars, 'cats' and O2 sensors go beyond 10 years The first time I replaced an O2 sensor is this year - Bank 2 Rear on a 99 I30 and Bank 2 Front on a 97 Q45. I expect to replace O2 sensors in the coming years but I hope the cat will last the lifetime of the car (knock on wood).
The 'cat' and O2 sensors can fail prematurely due to contamination (oil, silicon, phosphorous, etc), poor quality gas, engine misfire and/or continuous exposure to 'rich' air-fuel mixture. So make sure you don have intake/exhaust leak, your spark plugs are not over 100K miles and the fuel injectors are firing correctly.
